Meraki Air Marshal for Catalyst monitored APs
gregpalmer2
Wondering if Meraki AirMarshal works for APs that are in Meraki monitoring mode?
Inderdeep
Yes, Air Marshal works for Meraki access points (APs) in monitoring mode
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Air_Marshal
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
7 Replies 7
Inderdeep
gregpalmer2
Thank you
Inderdeep
welcome
RWelch
I think he meant to give you the SOLUTION versus it to himself 😁 (how is that even possible?)
CarolineS
Meraki Alumni (Retired)
@gregpalmer2 Thank you so much for coming back and marking the solution! However, I’m moving the solution marker to Inderdeep’s response (instead of your “thank you”) - since Inderdeep provided the info!
Cheers!
gregpalmer2
Hi. My apologies. This is my first posted question and I was traveling while posting. Thank you for correcting my very unintentional error.
CarolineS
Thanks for posting, and absolutely no worries! Glad the community could help.
