Max radio transmit power on MR57 - limited to 23dBm?
Russell_F
Recently started experiencing an issue with the radio transmit power on our MR57s.  For our environment, and based on our experience with prior Meraki APs (MR34s, MR52s), we saw anything from 26-30dBm transmit powers (as shown on Wireless -> Configure -> Radio Settings in the dashboard) on both 2.4Ghz and 5Ghz radios.
At some point in the last few months, we've seen the transmit powers drop significantly. Now everything maxes out at 23dBm across all radios.  I believe (but can't be 100% sure) that this started sometime after we upgraded the APs to MR57s.  At the same time, users started complaining about reduced WiFi coverage at the edges of our network, so pretty sure something is up.
By way of troubleshooting:
  • The APs are not operating in low power mode, as confirmed in the dashboard.
  • The Target power in the assigned RF Profile is set to 30dBm, and no radio has any manual override.
  • The MRs are running only GA code - currently MR 30.7.1.
  • We are not using any DFS channels.
  • We only have 3 APs so there's no overlapping bands between the APs.
  • We are not in a crowded RF space, with between 4-7% average channel utilization on the 5Ghz band as an example (and around 20% on the 2.4Ghz band).
  • The MR57 flex radio is set to a second 5Ghz radio (although have tried disabling it to see if it helps).
I raised a ticket with Meraki support, and after much back and forth over a period of a month, they've come back to me having "consulted with engineering" and are saying that because of the antenna gain in the MR57, the max transmit power that will *ever* be shown in Radio Settings in the dashboard is 23dBm, and therefore everything is working as it should.
This doesn't seem right to me (for all the reasons mentioned above) but, before I push back on support, I wanted to see if anyone else in the community could check their own dashboard and see whether they have any MR57s that are showing a higher Transmit Power than the 23 I mentioned before.  Hopefully it's someone in the same regulatory domain (I'm US based, so FCC).  If I can't find anyone else with something higher, I'll have to grudgingly accept their conclusions.
Thanks!
9 Replies 9
Russell_F
To add, I've reviewed the information at https://documentation.meraki.com/MR/Radio_Settings/RF_Profiles#Max_Radio_Power_Limitations, and I don't believe any of it would explain this situation...  but open to feedback.
  • Regulatory Domain - I’m in FCC/US so I understand this isn’t a problem?
  • Channel Selection/Band Edge - this is happening across all radios regardless of band, so not relevant to my situation.
  • Bit Rate - minimum bit rate on 2.4Ghz is 12, and on 5Ghz it’s set to 9.  Which I understand is relatively low.
  • AP Model - can’t find the RF performance table for the MR57, so if anyone can point me in the right direction, I’d appreciate it.
RWelch
Curious to hear if you are assigning separate RF Profiles to each AP?  Or one RF Profile to all 3 APs?
Not assuming this to be the culprit but I've had mixed results similar to what you described.
Russell_F
Same single RF profile is being applied to all AP radios.  I've set the target transmit power to 30dBm now, but at the beginning of all this is was for years set to 26-30.  However, it never goes above 23dBm....
I think its normal,it get 17 on lower and 23 on higher channels here in EU.  it has to do with antenna gain and beamforming that you have to add up.  Look at te last post here
https://community.meraki.com/t5/Wireless/Why-does-the-Target-Power-not-equal-the-Transmit-Power/m-p/...
Documentation
https://documentation.meraki.com/MR/Radio_Settings/EU_Compliance_Information
GreenMan
Meraki Alumni (Retired)
The rules are certainly different between Europe and the US (FCC, where Russell_F is operating) - and more restrictive in Europe (where I am too @ww )
From a quick look at the FCC rules, I think 30 dBm may be legal, but I seriously question whether you'd ever want to actively use it;  clients will not be generating that kind of output, so you'd likely end up with one-way transmission, if you're reliant on that kind of power setting.
I am going to take a different tack to the others (they have addressed it well already).
How closely have you looked at the clients?  Is it all clients with the issue, or only Windows machines.  Is it all Windows machines, or only machines with a WiFi chipset by a particular manufacturer?
Have you tried taking a problem device, and upgradig the WiFi drivers on it?  Don't use the OEM manufcaturers drive (such as Lenovo, Dell, HP, etc) - but get the actual drive from the WiFi chipset manufcaturer (such as intel).
This would have just as easily been a Windows/Device update.
Is it happening across all APs, or perhaps only a single AP?  Has there been any other newly added devices in the WiFi environment?  Cordless phones.  WiFi LEDs (saw a site recently where these flooded the WiFi network taking it down).
Do the clients report a good signal strength?
What does Wireless Health and Wireless Overview say?
Under Wireless Overview, do these show anything interesting (particularly with a known problematic client)?
I just re-read your post - you don't actually mention there being an actual issue that clients are experiencing.  You are simply noticed a different power level.  Are clients actually reporting issues?  If so, refer above.
Russell_F
Thanks for this!  I'll try and respond to each of your questions....
  • How closely have you looked at the clients?  Is it all clients with the issue, or only Windows machines.  Is it all Windows machines, or only machines with a WiFi chipset by a particular manufacturer?
    • Seems to be happening pretty consistently across all manner of clients.  Specific ones where there have been complaints - MacBook Pro (2019/15", and an M2), iPhone 16 Pro Max, Pixel 9 Pro XL, iPad Pro 11" (M4), Pixel Watch 2, Samsung S23.  No Windows machines.
    • The issue seems to be slower wireless performance than previously (note, that the performance dropped some time after the M57s were deployed, initially they were fine), slow download speeds, Zoom call drop-outs, etc.  Not necessarily when people are moving around, but always at the "edge" of the wireless conference.
  • Have you tried taking a problem device, and upgrading the WiFi drivers on it?  Don't use the OEM manufacturers drive (such as Lenovo, Dell, HP, etc) - but get the actual drive from the WiFi chipset manufacturer (such as intel).
    • None of the impacted devices have the ability to independently update drivers (no Windows or Linux devices).  We've been on users' backs to get their devices up-to-date, and I don't see anything more than a couple of months out of date, thankfully.
  • This would have just as easily been a Windows/Device update.
    • Quite a few OSes impacted (iOS/iPadOS, MacOS, Android, WearOS.  No obvious software update trigger.
  • Is it happening across all APs, or perhaps only a single AP?  Has there been any other newly added devices in the WiFi environment?  Cordless phones.  WiFi LEDs (saw a site recently where these flooded the WiFi network taking it down).
    • All 3 APs.  Always a trickle of new devices, mostly new cell phones and tablets.
  • Do the clients report a good signal strength?
    • It has dropped since whatever happened.  Users would report full/near full bars previously, now users often see as low as 1 bar (and that's when performance isn't great).  I am concerned that the roaming isn't as great as it should be, but I understand that's a client decision, and yet it's happening across all types of devices.
  • What does Wireless Health and Wireless Overview say?
    • On Health - looking back over the last month, I see devices that were used at the edge of the network with high % failed connections (~35%).  These devices didn't used to have problems BTW.
    • On Overview - last week has been "Excellent" for connection health and networks service health, and "Good" for performance.  Previously we've seen it as Fair on connection health, and Good on performance.  Can't change this view past a week so can't give you the last month.
    • Not surprising the health looks better for the last week as many folks are only coming back from holidays now.
  • Under Wireless Overview, do these show anything interesting (particularly with a known problematic client).
    • The only devices that show as problematic are the ones used at the edge (as listed earlier)... that's the only connection I can see.
  • I just re-read your post - you don't actually mention there being an actual issue that clients are experiencing.  You are simply noticed a different power level.  Are clients actually reporting issues?  If so, refer above.
    • I think I covered this in my other answers... but yes, it's having client impacts on speed of access (videos, downloads, etc.) and communication/meeting tools (esp. Zoom, but also WebEx).
Appreciate the help, thank you!
Russell_F
I should add, looking at "Timeline", 5Ghz seems to be a problem for many of the impacted devices... SNR is often <15dB before these devices roam.  Again, never used to see such low SNRs prior to the lower Transmit Powers.
thomasthomsen
I have previously done some testing on the Meraki APs regarding max transmit power an different external antennas, versus the maximum allowed EIRP in my regulatory domain (Denmark / ETSI) because the external ones , especially the MR46E had a clear problem when compared to a normal Cisco AP.
I never got around to testing on 5Ghz. 😕 Sorry.
But my results are here : https://docs.google.com/spreadsheets/d/1-s5IOMg09DTCFnODNapsYXta_onfO4W6SqG3E6sn9tg/edit?usp=sharing
I your case, the antenna gain on 5Ghz in a MR57 is 5,5dbi, and the max EIRP in the US (as far as I remember) on UNII-1 is 23dbm (200 mWatt), on the UNII-3 channels in the US its 30dbm (1 Watt) ??
So the offset, if the AP is running in UNII-3, and you have your 23dbm radio power + 5,5dbi antenna gain =  28,5dbm EIRP , is missing 1,5 dbm of transmit power.
Perhaps that AP is not able to turn up / down the power in such small db steps (this is me speculating, I have no knowledge of this).
But it could mean that this is the max power of that AP.
