MR28 Universal Mounting Bracket SKU
Ferguson79
I cannot seem to find the SKU for ordering a replacing mounting bracket for the MR28. Its not listed in the any of the Meraki documentation. Does anyone have any insight, or would the MA-MNT-MR-12 for the MR20 Also work for the MR28? I do not think this would be the case since the dimensions are different.
BlakeRichardson
Looking at the datasheet and the below website the MR20 mount looks identical to the MR28 mount. That has a part number of MA-MNT-MR-12
https://www.cloudwifiworks.com.au/Mount-Kits.asp?srsltid=AfmBOooh0pWPm4wrL-Y4Oopdxe5xZHaM8brsDSPV5tn...
2 Replies 2
RWelch
While I do not know what the MR28 bracket mount SKU is, it appears the data sheets to show identical physical dimensions for your consideration:
MR Overview and Specifications
BlakeRichardson
