Do you have any meraki support case open?
typically, client likes to join 6GHz, if 6GHz broadcast higher connection speed. (e.g enable 80MHz or 160MHz Channel width) even when 6GHz RSSI is much lower. than 5GHz.
one idea is reduce the Channel width of 6GHz, matching with 5GHz. and you can apply higher TPC range (min-Max), so you can make sure 6GHz has similar SNR as 5GHz
