Live Statistics
BlakeRichardson
Live Statistics
Hopefully I this is an easy one and I am just not looking in the right place because it's Friday and I am hanging out for a beer..
I am trying to see the live stats for how many clients are connected to an SSID, I am sure I've done this in the past but for the lift of me I cannot remember how.
Network-Wide >Monitor > Clients only goes as short as last two hour and doesn't let me narrow my search based on an SSID ( This would be useful!)
6 Replies 6
Brash
Not sure if this is exactly what you're after but it might get you a bit closer:
Filter "Status: Online, Connection Type: Wireless"
Add "Recent SSID" column via the spanner
Sort based on "Recent SSID" column
Manually count or download CSV
BlakeRichardson
Thanks @Brash  but it only narrows it down to the last 2 hours. I need current stats.
I will be naughty and say other vendors have this info....
Brash
Ah, I was under the impression that by filtering "Status: Online" you'll only get currently connected clients, and exclude historical clients. That said I've not tested to confirm.
@BlakeRichardson you can see it on the AP summary page, but I don't think across multiple APs?
Hmm.  You can see clients by APs:
If you go into Wireless Health and select the "Last Hour" you can also select each SSID to get an "indication".
AxL1971
I wrote some software using API calls to collect this information, write it to a back end SQL database and a front end web site to show the information for each office and number devices conenctions.
Other details I collected was channel utilisation.
Also used Power BI to create fancy graphs.
