How can I block a website from the entire wireless network?
The1Metallian
If I go to Wireless -> Firewall & Traffic Shaping, I have to go to each SSID one by one. I looked up and found that I have to go to Security & SD-WAN > Content Filtering, but I'm not finding that option, so maybe it applies to a different product.
Mloraditch
You have two options one is you would need to hand your wireless off to a VLAN that is built in your MX and then use a group policy on that vlan to do the blocking
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
or you can use layer 7 rules per ssid https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_a_Layer_7_Fi...
8 Replies 8
Mloraditch
The1Metallian
Well, I didn't want to go per SSID but the other option is even more involved, so I will do each SSID individually.
It seems to me that it should be an option to do this network-wide.
Thanks for the prompt reply.
DarrenOC
Do you have a Meraki MX in your network?
The1Metallian
No. Cisco ASA firewall, about to switch to FortiGate
KFoster
DNS sinkhole. Configure a rule to block http/https to the fqdn of the destination.
The1Metallian
I use different DNS servers per SSID. For Guest I have OpenDNS, for business associates Meraki Default, for corporate laptops my in-house DNS... I wanted one rule to block for all SSIDs
KFoster
I believe I understand what you are trying to describe. Ultimately, your edge firewall will make the decision to allow or block that traffic, regardless of what the endpoint is configured to point to for DNS.
I would recommend reviewing the DNS policy options that are available for your specific ASA platform, but here's an example: Cisco ASA with FirePOWER Services Local Management Configuration Guide, Version 7.0 - DNS Policies [...
Once you have a network object created with the FQDN of site you are trying to block, you can then define an ACL rule where the subnet for that specific SSID is not allowed to hit the external resource. This assumes you have a separate subnet for each SSID / network.
The1Metallian
Thank you
