Disallow access to other device but still access another VLAN
Darian
A client of ours wants to setup multiple SSID's for each of their 'teams' and separate them using VLANs and L3 firewall rules. We are trying to talk them out of this and just doing 3 SSID's a guest, private, and a team making those teams connect to the "Team" SSID and making it so none of the devices can communicate with each other. We know you can accomplish this by using the meraki DHCP but they also have a network printer that those devices will also need to connect to on another VLAN. Is it possible to make it so they can communicate to the printer vlan but not to other devices on the "team" vlan?
For example:
I have a laptop on the "Team" SSID using VLAN 2 and need to print to a printer on VLAN 1. However, I should not be able to setup a network share or ping from my laptop to my desktop if both the devices are on the same "Team" SSID.
Make a rule to block vlan team to vlan team.
You can also look at ipsk if you want different teams to have different vlans and still use 1 ssid
Or wpa2 ent with radius
Darian
Thank you, I'm going to try the ipsk without radius for Meraki (they don't have a on-site server) and see how that goes!
Bruce
@Darian, not sure about iPSK as a solution to this, but you could use Layer 2 isolation on the VLAN to prevent clients ‘talking’ to each other. With Layer 2 isolation (SSID needs to be in bridge mode) clients have to communicate through the default gateway. See https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Wireless_Client_Isolation.
