Aug 23 2021
11:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Aug 23 2021
11:37 AM
Auto clients disconneting
Hi All,
I am trying to find away to automatically disconnect client from APS when they are not using it, is there a way to do this in Meraki?
Solved! Go to solution.
Labels:
- Labels:
Other
Aug 24 2021
6:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Aug 24 2021
6:28 AM
@Rasha : there is no timeout option. The session will only terminate once the user clicks disconnect
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Aug 23 2021
4:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Aug 23 2021
4:40 PM
Guessing you're looking for a user idle timeout value that you can set, I don't believe Meraki has this option available but support might have a sneaky setting that can be enabled by asking?
Aug 23 2021
7:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Aug 23 2021
7:55 PM
Yes that's right,I will check with the support, Thank you.
Aug 24 2021
6:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Aug 24 2021
6:28 AM
