Delete a disabled SSID
FBettencourt
I am cleaning up my SSIDs and am not seeing how to DELETE an SSID, whether enabled or disabled.  Thoughts?
Bettencourt
First of all, CONGRATULATIONS ON YOUR SURNAME, it's the best I've ever seen.
Secondly, unfortunately, that feature is not yet available, you will have to disable it for now, however, please login to your dashboard and click the button Make-a-Wish to suggest this change to Cisco Meraki.
7 Replies 7
Rename it back to Unconfigured SSID 1 or similar when disabled and it will disappear from client lists
DarrenOC
Hi @FBettencourt , as @cmr states, you can’t delete only disable.
DarrenOC
Also think this one needs to be moved to the Wireless section
@CarolineS , @MeredithW  😁
FBettencourt
My bad.... wasn't familiar with "Insight" as a product.  I thought this was a general insight board...lol
DarrenOC
@FBettencourt , no dramas.
CarolineS
Meraki Alumni (Retired)
Moved!
Bettencourt
