Computer shows splash page but there is no configuered
Tuvestam
I have a Windows 10 computer that till show a splash page while i connect to our SSID. All other computer connecting to the same SSID does not have this. If I try to connect to another SSID on the same AP there is no problem.
Tuvestam
It looks like it's Microsoft redirection to check if there is network connection. Thank you for the time
10 Replies 10
Do you have an MX on your network that has access control configured?
Tuvestam
We have a MX but the access control is not configured (set to None (direct access)).
Okay, but is this page a Meraki page? Or is it a random page?
Tuvestam
msn.com
Well, have you checked the configuration on the workstation? Have you tried changing the default browser on the workstation?
Tuvestam
Yes and I don't get it on an other SSID that is from the same AP etc. I have reset the network and everything. I can se that the connection also is w8 on confirmation from the splash page. But as ther is none it will not work.
Well, I don't think It's a Meraki issue, but you can try to forget the network on the workstation. Feel free to share the SSID configuration.
Tuvestam
Well as it works on other SSID without geting a splash I think it is. But other computers does not have this problem.
Tuvestam
BlakeRichardson
Glad you worked it out and thanks for sharing the answer.
