Cisco Meraki and Intune
Mohsin-
We're moving to Intune and trying to implement an Intune policy to authenticate devices using the NPS Radius server and on-premise CA certificate server. I would appreciate guidance on this.
Thank you.
MartinLL
Well, in the dashboard you configure your radius server pr network, template or globaly. Point to the NPS IP, create a shared secret and off you go.
Remember that the radius requests originate from each devices management IP. You need to make sure that NPS accepts radius requests from those IPs.
Other then that it is mostly client, intune and NPS config.
MLL
BlakeRichardson
You can use a proxy but then you have to allow external traffic to your NPS server.
If I understand correctly - all you are trying to do is configure the WiFi settings on the end devices.  Most likely you want to create a WPA2-Enterprise mode SSID on the machines.
https://learn.microsoft.com/en-us/mem/intune/configuration/wi-fi-settings-windows
