Unable to Reset Cisco Meraki MR46 Due to Lost Password
Waqas1
I have a Cisco Meraki MR46, but I have lost its password. When I try to reset it using the reset button, it doesn't reset.
Is the device online on the dashboard?
The password should be on your meraki dashboard. Network-wide >general> device config
You can also try,
use the serial number of the device (upper case letters and dashes) as the username with no password.
If it doesnt reset pressing the button 30 seconds then you should contact meraki support
GIdenJoe
Also if you correctly hold down the button you should see the led flashing and when it stops you may release the button.  It will then revert back to the serial number as username.
This is the procedure to factory reset an MR.  I promise you - it does work.
https://documentation.meraki.com/General_Administration/Support/Resetting_Cisco_Meraki_Devices_to_Fa...
Also note that if you are talking about the local status page password, as soon as the MR has been factory reset it will download its configuration and restore the password.
The username will either be the serial number in captials, and no password, or whatever you have configured under Network-Wide/General.
