Cisco Meraki Catalyst 9300L-48PF-4X
andyyu1
I am considering using the Cisco Meraki Catalyst 9300L-48PF-4X. Is it possible to physically connect it with equipment from other manufacturers, such as the SG350, SG200 switches, UniFi UCK G2 Plus, and the UAP-AC-HD WiFi 5 AP?
Mloraditch
Yes it will generally work fine, with other switch vendors you may need to look at your STP design carefully, but otherwise it's still just a switch and none of the hardware you've mentioned has any vendor lock in requirements that I'm aware of for basic operations. If you need more advanced features there may be other considerations.
7 Replies 7
Mloraditch
andyyu1
Thank you for providing the information.
andyyu1
Inderdeep
yes it will be fine
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
andyyu1
GreenMan
Meraki Alumni (Retired)
As Mloraditch mentioned;   yes, but take care with Spanning Tree:
"C9300 (and MS390) runs single instance (0), single region (region1), and single revision (revision 1) MSTP. This is essentially Rapid Spanning-Tree. Please make sure for interoperability with any other non-Meraki platforms, to either run Rapid Spanning-tree or MSTP (not PVST or any iteration, nor any other vendor specific STP implementation). This will ensure that there are no issues with compatibility and functionality."
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Configuring_Spanning_Tree_on_Meraki_...)
andyyu1
