Can I do a firmware downgrade pass the 14 day grace period?
neosim
I need to downgrade my APs to a later version, but it has passed those 14 days period. Is there way to do this manually or not? Thank you.
8 Replies 8
No, It's not possible after passing the rollback deadline.
neosim
That's a bummer. Well, they need to fix that and make it possible. Do you know why 14 days is the magical number?
It is defined by Meraki. Maybe you can ask support to help you.
VRB
14 days is for 2 weeks..
BlakeRichardson
Support might be able to manually do this for you. I guess 14 days is where they draw a line in the sand.
DarrenOC
Contact both your Meraki AM and support.  It’s more than doable
RaphaelL
Yes you can downgrade to almost any possible version. You have to ask support to pin that version. Simple as that.
BaskaranGanesan
Recently, I have downgraded the AP to an old version with the help of Meraki support.
