Black MR42 covers?
CotyMick
Black MR42 covers?
Hey!
Can anyone recommend a black cover for the MR42?
Thanks!
Mick~
16 Replies 16
Adam
Maybe message these guys and see if they have or can make one for a MR42 https://coverandhyde.com/
I feel like some type of stretchy fabric would work well and not impede signal.
They look cool @Adam!
CotyMick
@Adam Thanks
CotyMick
@Adam I'm actually looking at the
33-MR53-COVER
Here:
https://oberoninc.com/products/wap-vanity-covers
Adam
@CotyMick I saw those but it looked like a metal box.  But now that I read the spec it says they are plastic and don't impede the signal so may be fine.  Would be interesting to test.
MerakiDave
Meraki Employee All-Star
Hey team, a colleague and I just had this conversation with a customer recently. We found a local sign shop that does vinyl graphics & wrapping.  They wrapped the APs for around US $30 per AP.  It was for a zoo and they wanted the outdoor APs to blend in.  Some where camo, some were brick pattern, some just matched the wall color.  I’d search for local sign shops or someone that does vinyl car wrapping for example.
I did a couple quick searches and the stuff is fairly cheap and also looks pretty simple to do (depending on how much of a perfectionist you are!)  Here’s someone doing a laptop. https://www.youtube.com/watch?v=WvSCkLNPb30
Maybe we'll see a video sometime soon of someone vinyl wrapping a Meraki AP?!?
Hammer
@MerakiDave How would wrapping a Meraki AP in vinyl affect its warranty?
sfpete
It appears the painting the units is indeed a semi-supported solution, albeit still voids warranty. Would be dead simple to tape off and spray...
https://documentation.meraki.com/zGeneral_Administration/Inventory_and_Devices/Painting_Cisco_Meraki...
Thygesen
@sfpete @mmentges @MerakiDave
It seems that the link has been redrawn/removed ..
How is Meraki's take on spraypainting the cover (non-metallic paint of course) of an AP ?
Bruce
A safer approach is to cover them with vinyl since it can be removed.  Check out:
Thygesen
Hi @PhilipDAth ..
Or get somebody to do a spare-time project making covers/bags in Clan-colors ..
Can't be that expensive ..
GIdenJoe
I remember Batman saying to Mr Fox about the tumbler:
Does it come in black?
MerakiDave
Hey team sorry I was offline for a few weeks and just checking back, I had to get through the 350-401 Cisco exam, failed it (by just a few points) 2 weeks ago and then got a solid pass 2nd time around yesterday, so I was neglecting the Community for a few weeks. 😁      @Thygesen the other answers are correct, technically speaking, you can certainly spray paint an AP with the non-metallic paint as you mentioned and it would likely work fine, but the warranty is void.  I mentioned in another reply above about vinyl wraps, and yes they'll work great, and to my knowledge they do NOT void the warranty like paint does.  That'll be your best bet to have the APs blend into the environment, vinyl wraps are effective, safe, and cheap.
CarolineS
Community Manager
Community Manager
Congrats, @MerakiDave!
Caroline S | Community Manager, Cisco Meraki
mmentges
I wrapped my personal AP at home and am contemplating it for my new install... Stuff I got on amazon peels off easily and leaves no residue any different than a normal label. Looks good to me will be trying on next install. its 3.5mil thick.... cant impede anymore than a wrap or box.
