1 of 6 APs running much slower than the rest (MR46)
jlock8191
Good morning, all!
I inherited a Meraki network and am loving the simplicity. I noticed in one area of the office users were letting me know of slowness.
I ran a speed test and got about 50mbs, I also ran a throughput test via Meraki and it didn't show much better at 80mbps
All 5 other APs are all working find with over 600mbs.
I have already rebooted the AP and unfortunately no change occurred.
Any ideas? I am doing research online, however it seems most the AP slowness issues are regarding all the APs and not just one.
The AP is a MR46
Thanks!
6 Replies 6
I suggest you open a support case.
DarrenOC
Hi @jlock8191 , have you compared the switchport configuration of an AP with higher throughput and compared it to one showing lower throughput?
jlock8191
Thank you! I am looking at this now and seeing that the auto-negotiate on the switch port with the slow AP is coming up as 100mbs.
Now I just need to figure out why. Digging now, just glad I know where to look. Thanks again!
DarrenOC
Hi @jlock8191 , as mentioned below try bouncing the switchport.  Maybe also run a cable test on the affected port.
jlock8191
Thanks! I tried both with no luck but I am starting to see a pattern. Looks like it is oddly all ports on Switch 1, up to port 18. After port 18, everything is 1gig.
All the rest of my switches are fine and negociating at 1gig.
I noticed have a firmware update to run, I am going to give that a shot and see if it resolves the issue.
Shubh3738
@jlock8191 Reboot your AP, Check channel Width or Switch Port configuration or if available do the firmware upgrade.
Hope! These above things resolve the issue.
