Pre-shared Key Authentication not working
Naresh_Bhardwaj
Hi All,
I'm using Pre-shared Key as an Authentication method for SSID's configured on Meraki dashboard for MEraki AP's
However when users are connecting to the Wireless they are not getting any popup to put Key and getting connected to the SSID without putting the Authentication Key. The IP address they are getting correctly from the same VLAN to which SSID have been map.
Can someone please help
5 REPLIES 5
BlakeRichardson
@Naresh_Bhardwaj  Can you please post a screenshot of your SSID's settings.Have you set a WPA encryption mode as shown below?
www.btr.net.nz
Hi BlakeRichardson
Please find the below
@Naresh_Bhardwaj  has this SSID ever existed on another device before you set this up with Meraki, could the devices be remembering an existing network?
www.btr.net.nz
@BlakeRichardson
hi
We are using the new SSID's
DarrenOC
Hi @Naresh_Bhardwaj , what firmware are the APs on? We’ve seen similar behaviour in the past which was resolved by a firmware upgrade.
