Hi all,
We have a lot of older Cisco 2602 AP and we need to connect some Coffe Machine to the Network. (this is not a Joke) if we now configure the correct SSID on the Cisco AP (even with open security) the Cisco AP is not Connecting to the Meraki AP.
dies anybody done this type of configuration yet?
Thanks for any Help
You will have to configure the 2602 in workgroup bridge mode.
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/68472-configure-wgb-00.html
Were you able to get this to work ? I have the same need, and am able to get the WGB to associate fine. And it can ping the ethernet device fine (same subnet as the WGB & SSID/VLAN). But no traffic for it is being passed across the association.
I have the same issue. Autonomous Cisco 3702's connected to a burn table will not connect to our Meraki MR46E AP's. I can see them connect but will not get an IP address. I called Meraki support who said they was not compatible but could not give me an article stating that. If they are not compatible, can you suggest a devise to use that would be compatible to connect our devices that have an ethernet port but are not wireless to our Meraki WIFI?
At least you won't have to worry about HTTP 418... I would listen to Phillip. He knows a great deal about Cisco kit.
