Support Data Bundle (SDB) question
Lourdes
Hi everyone,
May I ask if the SDB will be deleted if we reboot the device? Ex. Firewall
JamesT91
Yes, grab the logs before you reboot.
I don't know the answer.  As @JamesT91 says, I would try and grab it before device reboot, but I would be surprised if it couldn't capture some kind of persistent log information after reboot.
ConnorL
Meraki Employee All-Star
Hey @Lourdes ,
When you use the SDB tool, it'll automatically download the file to your computer - this may take 10-60 seconds to complete depending on the state the device is in.
The file is generated on-demand when you use the tool, so if you're experiencing an issue and Support asks you for an OOB/SDB (Out of band / Support Data Bundle) file, make sure you do this before rebooting the device, else a lot of the logs that are helpful to support may be lost or no longer relevant.
Cheers,
Connor
Lourdes
Okay. Thanks for the info.
