Looking for some design advice...
I have 2 MX's in HA mode and two ISP's
Each ISP only provided one physical port.
I therefore need to put 2 switches between the MX and the ISP router as below:
WAN1 on each MX has a public IP from ISP1, WAN2 on each MX has a public IP from ISP2.
I also have a public IP from each ISP for the VIP.
If I were to use Meraki, how would I configure these so they are accessible via the dashboard (IP addressing, do I need to link them, what would the gateway be etc etc)?
Would the following work...
Connect them to the MS switch on the LAN side of the MX and make that an access port in the network mgmnt VLAN - would that make them accessible via the dashboad as shown below:
or is there a better way?
Or am I better off just using 2 unmanaged switches, and if so can anyone recommend a 8port model, ideally Cisco. The intention would be to have to plug into these direct in order to configure.
Preference is to stay with Meraki if Option 2 above will work.
TIA
Steve
