Management Vlan SVI
Mac1
Management Vlan SVI
Hello. I've read here that Best practice suggest using a management vlan
So lets just say I want to use 10.1.1.0/24 as management for reachability to the cloud (this will be natted)
should this 10.1.1.0/24  be configured on my layer 3 gateway as a normal SVI along with my Data & Voice svi's and whatever else?
Inderdeep
@Mac1 : Well check the below thread for best practices. I would say always separate management and user data traffic VLANs and if possible not to use the Native VLAN ( Hardening)
https://community.meraki.com/t5/Security-SD-WAN/Best-practices-for-native-VLAN-configuration/td-p/48...
I can give my native vlan whichever number i want, right? It doesn't have to be one does it?
Yes, you can have any number and dont use 1.
Regards/Inder
www.thenetworkdna.com
5 Replies 5
Aaron_Wilson
That is how I do it
Inderdeep
@Mac1 : Check this out
By default, the switch will try to contact Meraki Dashboard on the untagged (native) VLAN. Alternately, you can specify the management VLAN under Configure > Switch settings. This allows the switch to reach the internet via a trunk port.
https://documentation.meraki.com/MS/Other_Topics/Switch_Settings
Regards/Inder
Mac1
Thanks Inderdeep. So what is the best practice?
Native vlan or separate managment network?
Or use the Native vlan  with the intended /24 network you were going to use as managment?
Inderdeep
Regards/Inder
Mac1
Thanks for your help. Much appreciated.
