Stack meraki with Catalyst
Matt_Wade
can we stack ms355-48x2 with c9300x-48hx-m
Brash
No, you cannot add an MS and a Catalyst switch to the same physical stack
Only like-models can be stacked. For example, MS350-48 and MS350-24X can be stacked, but MS250-48 cannot be stacked with a MS350-48. The only exception is that MS210 and MS225 models can be members of the same stack.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Configuring_a_Physical_Switch_Stack
DarrenOC
You could daisy chain the switches together to form a physical stack of switches using their SFP+ uplink ports.  But you couldt stack them in the traditional sense using their stacking ports nor add them as a stack in the dashboard.
Inderdeep
No you cant do that
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
