Unable to Factory Reset MS350
MattMedix
Hello, we have had some trouble with our MS350 and now I cannot factory reset the device. Holding the reset button for 5 second, or 30 seconds. The status light never changes from amber. Does the device need to be connected to the network to initiate a factory reset?
Thank you!
10 Replies 10
RWelch
Resetting Cisco Meraki Devices to Factory Defaults
RWelch
MS Access Switches
To reset a switch to the factory defaults, press the button labeled Reset or Restore on the front panel of the switch for 10-15 seconds. Be sure to release the button after 10-15 seconds or when power light goes out (whichever occurs first). This will clear the static IP address settings and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
Note: Holding the reset button after the switch reboots will place it in factory test mode. If this has occurred, reboot the device to return it to normal behavior.
RWelch
DarrenOC
If you’re unable to factory reset the device or it’s failing I would contact Meraki support as they’ll RMA the device.
MattMedix
It’s starting to feel like I’ll need to RMA the device 😕 is anyone able to answer if a successful factory reset requires the device to be connected to the network? Also, does this device have a protection from factory reset?
Thanks,
M
RWelch
To INITIATE a factory rest, it needs to be plugged into POWER.
For it to fetch a new config file (AFTER) factory reset it will need connectivity to the internet (cloud).
MattMedix
Okay so a network is not needed to initiate a factory reset, only power. After, the network is used to pull down the config. Understood.
Could there be a factory reset protection preventing the reset? I’m unfamiliar if the MS350 even has that feature.
Thanks!
RWelch
😅Yes as mentioned above:
Note: IF YOU HAPPENED TO HAVE MISTAKENLY HELD the reset button after the switch reboots IT WILL place it in factory test mode.
IF THIS HAS OCCURRED, reboot the device to return it to normal behavior.
Hope it helps 😅
RWelch
Maybe just call Support as they'd likely walk you through this process/steps.  And if it fails, then you can let them start the RMA process 😉
MattMedix
Okay, that helps. I may have to reconnect the MS350 and check the factory reset protection setting, but it’s probably best if I do that with support accompanying me.
Thank you.
