Stack MS425 with LR?
gosse
Can the MS425 switch be stacked with 40G LR transceivers instead of stacking cables?
Inderdeep
Flexible stacking is available on MS425 switches, which do not have dedicated stacking ports; any SFP+ interface on these switches can be configured as a stack port. You can use 2 x 10Gb/s (SFP+) or 2 x 40Gb/s (QSFP) interfaces can be connected together as flexible stacking ports. Have a look on the below document ad let me know if it answer your query ?
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Configuring_a_Flexible_Switch_Stack
Regards
Inderdeep Singh
www.thenetworkdna.com
Regards/Inder
3 REPLIES 3
Theoretically yes, there is nothing special about the stacking cables, they are just normal DACs.
Inderdeep
Regards
Inderdeep Singh
Regards/Inder
The following are listed as compatible:
MA-QSFP-40G-LR4 (single mode)
MA-QSFP-40G-CSR4 (multi mode)
MA-QSFP-40G-SR-BD (multi mode)
