Benefits of Meraki Switches
Kevin1
Hey Folks, Does anyone know where I can get my hands on a doc. or link showing the cost and Tech. benefits of the MS Switches over HP Procurve.
BrechtSchamp
Meraki partners have access to collateral on the partner portal.
There's some competitive info on it.
https://merakipartners.com
But tbh the biggest selling point is the dashboard. Which isn't quantifiable in feature tables. After you play around in the dashboard for a day you'll probably be convinced. Same goes for customers.
6 Replies 6
Nick
Specifically against the Pro Curve I do not have, though a Meraki rep should be able to furnish you with some helpful points.
There is this key overview of the benefits of the switch Key Switch Features
Do you have access to the Meraki Partners section?
Kevin1
Thanks Nick, this helps, I had a reseller partner looking for a vs HP doc. to show his end user. I recommended he would be better served speaking with his Meraki rep.
BrechtSchamp
GreenMan
Meraki Alumni (Retired)
Just one additional thought, Kevin;  the real benefits of Meraki switching (indeed any Meraki product) can't properly be seen in a document - you and others involved in the choosing really need to experience them in the context of the Meraki Dashboard.  Maybe try getting onto a Meraki Webinar:    https://meraki.cisco.com/webinars , or get hold of your local Meraki sales team, for a Dashboard demo?   https://meraki.cisco.com/form/contact
Kevin1
Thank you GreenMan and the other contributors for your responses and passionate defence of the Dashboard. I have seen the it in action in our ATSC Centre at Tech Data Canada.  Our Meraki Master Mahmoud is equally passionate and ready to defend the Meraki Dashboard against all comers. He is usually my go to person, but I am glad to know I have a Plan B. It was the customer requesting the vs Aruba doc. Cheers !
DHAnderson
As others have said, the dashboard is the key.
Visibility into your complete network stack, no matter where you are, no matter where equipment is, cannot be understated.
Some switch specific benefits(no matter where the switches are physically):
See all switches in a network in one view.
See all ports in a network in one view.
Drive down into a particular be port in a network quickly.
Test a cable without being onsite.
Dave Anderson
