I am replacing our Core Switches (Cisco Catalyst 9200L) with Meraki MS-425's.
Can I utilize the configs from the C9200L on the Meraki MS-425's. Is there any process that you can provide that will make the conversion process easier?
We are doing the swap on this Saturday.
Thanks for any information or suggestions you can provide.
Regards,
~ Jerry
Solved! Go to solution.
I'm sure you are onto this already, but the 9200L is a Gigabit Ethernet only switch, while the 425 is a 10Gbe SFP+ only switch (ignoring uplinks in both cases). You can't plug Gbe into an MS425 unless you have an SFP.
Nothing automated that I am aware of or would trust. Since you can configure the Meraki easily even without even needing hardware online I would just get two laptops/windows/monitors side by side and start configuring the new stuff based on the existing config output. Good luck and of curiosity how many switches are you talking about?
Four Meraki MS 425's
Yeah, I would just get started manually configuring them. If it was dozens or more switches it might be worthwhile to do something with the API, but I guess you can knock these out in a couple hours or less and be done. good luck!
As @BrandonS states you could knock these out in no time.
Review the Config from your current core. Note down vlan port assignments and configure like for like on your new core.
Same goes for your L3 VLANs, IP-helpers and routing.
Make sure your L3 interface for your switch management resides on your upstream firewall.
Thanks for the info Brandon.
Understood.
