Hi CommunityMeraki MS switches don't provide any information on how much RAM, CPU, etc?
Solved! Go to solution.
That's correct, MS resource utilisation is not present in the dashboard.
However Meraki Support does have access to this information on their backend if you're encountering/troubleshooting an issue.
