Power stacking C9300X
SimonReach
Installing 2 C9300X-Ms this coming weekend.
I know i require 2 data stacking cables, going from stacking port 1 to port 2 on both switches.  Never stacked power before though and i can't find if i need 2 power stacking cables as well or if a single power stacking cable is fine?
Inderdeep
Power stacking should use two cables the same as data stacking.  Both will 'work' with one cable, but are designed to operate as a ring, so you may get issues when using one.  On the other hand I have seen both work for many months just with one cable, it just is not recommended!
Inderdeep
SimonReach
Thank you, looks like it's done the same as the data so will do that.
GIdenJoe
Also it is best practice to have at least one switch in your stack with dual power supply.  It is not intended to work with all stackmembers only having a single psu.
