We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
Hi,We purchased 20 9300L switches in the Meraki version, the switches display output on startup but after that you can no longer see anything in the CLI.Is this correct?Does the 9300 in the Meraki version disable the ability to manage via CLI.
sw Version 17.9.3m4
Solved! Go to solution.
Correct. There is no console access in Meraki mode. All management is via the dashboard.
Check out this
https://documentation.meraki.com/MS/Deployment_Guides/Getting_started%3A_Cisco_Catalyst_9300_Managem...
Once in Meraki Mode there will no longer be console access
