Hi all,
i have a MV32 which i did not install on the ceiling. Instead i have the camera installed on the floor or on a table.
So now my video in the dashboard is up side down. Is it possible to turn the video a 180 degrees?
many thanks
Roger
If I remember correctly the turn 180 feature in the dashboard is just to rotate the whole circular projection 180°. Just like you would rotate the camera 180° on the ceiling. Afaik you can't rotate 180° "upside down". Make a wish ;).
Thanks for the answer...I thought initially to do a wish...but thought then to ask the community.
Hey @rwiesmann,
Go into the camera, and then under Settings > Video settings you should see the first option is "Rotation". You can flip the view 180° there.
We need an Upside Down button!
@DonAnnett wrote:We need an Upside Down button!
Indeed. There seems to be some misunderstanding about what the rotate function does and what @rwiesmann wants.
First, what the rotate button actually does:
Before:
After (sorry I was lazy and just flipped the image myself, ignore the timestamp):
Imo this doesn't make much difference for most users as it's a 360° view, the initial view when changing to DPTZ view is different, but that's about it I think.
What the OP needs is to flip the DPTZ image the right side up when the camera is not ceiling mounted but floor/desk/whatever else mounted. So flip this around:
I hope that clears up the confusion...
I like you comments...i really need this upside down button 🙃
