Hi All,
I am planning to use the Meraki Security Cameras MV22 - Indoor and MV72 - Outdoor. But it will be using the HP PoE switch for the physical connectivity and SOPHOS Firewall for the Internet access.
I would like to know will there be any challenge or it should be straightforward once i will connect these Meraki Security Cameras to the LAN (which has the Internet Access already) it should work fine.
Any thoughts or suggestions ???
The MX72 needs 802.3at power, so make sure the HP switch is 802.3at.
When you log into the Meraki Dashboard you can go "Help/Firewall Rules" in the top right hand corner. That will give you the rules to configure on your Sophos firewall.
Hi Phil,
This is the switch we have got. Will this work?
Product: HP J9773A
Name: HP 2530-24G-PoEP Switch
show power-over-ethernet
Status and Counters - System Power Status
Operational Status : On
Usage Threshold (%) : 80
Chassis power-over-ethernet:
Total Available Power : 195 W
Total Power Drawn : 12 W +/- 6W
Total Power Reserved : 12 W
Total Remaining Power : 183 W
Internal Power
Main Power
PS (Watts) Status
1 195 POE+ Connected
When i see the datasheet it looks good to me.
https://www.arubanetworks.com/assets/ds/DS_2530SwitchSeries.pdf
When it comes to SOPHOS Firewall Rules if i will allow any/any from the Security Camera VLAN. Will that not work ?
@SCC wrote:When it comes to SOPHOS Firewall Rules if i will allow any/any from the Security Camera VLAN. Will that not work ?
this will work... Or as Philip said, you can configure the following:
Dashboard (top right) -> Help -> Firewall Info
Source IP | ||||||
Destination IP | ||||||
Ports | ||||||
Protocol | ||||||
Direction | ||||||
Description | ||||||
Devices using this rule | ||||||
Your network(s) | 64.62.142.12/32, 108.161.147.0/24, 199.231.78.0/24, 209.206.48.0/20 | 7351, 9350 | UDP | outbound | Meraki cloud communication, VPN registry | Access points, Cameras, MX Security Appliance, Phones, Switches |
Your network(s) | 64.62.142.2/32, 108.161.147.0/24, 199.231.78.0/24, 209.206.48.0/20 | 80, 443, 7734, 7752 | TCP | outbound | Backup configuration downloads, Backup firmware downloads, Splash pages, Backup Meraki cloud communication, Throughput tests live tool | Access points, Cameras, MX Security Appliance, Phones, Switches |
Your network(s) | Any | 123 | UDP | outbound | NTP time synchronization | Access points, Cameras, MX Security Appliance, Switches |
Your network(s) | 8.8.8.8/32 | 53 | UDP | outbound | Uplink connection monitor | MX Security Appliance |
Your network(s) | 10.1.220.81/32 | 1812 | UDP | inbound | 802.1X with customer-hosted RADIUS | Access points |
Your network(s) | 8.8.8.8/32, 209.206.48.0/20 | ICMP | outbound | Uplink connection monitor | MX Security Appliance |
