Meraki panic buttons connect to Meraki portal through Ruckus APs / wi-fi network?
TomMc
HI, I'm guessing the answer is no but wanted to see if there was any way to use Meraki panic buttons and bluetooth connect to a Ruckus access point / wi-fi network and eventually be managed by the Meraki portal? (no Meraki AP's, cameras, switches)
Thank you,
BlakeRichardson
No, Meraki MT hardware will only connect to Meraki MR and MV devices.
ConnorL
Meraki Employee All-Star
I assume you're referring to MT30-HW Smart Automation Button, in which case indeed you need an MR Access Point or MV Security Camera as a gateway in order to use it. 3rd-party gateways are not supported.
For more info, see: https://documentation.meraki.com/MT/MT_General_Articles/MT_Frequently_Asked_Questions#How_do_MT_sens...
BlakeRichardson
TomMc
Thanks Connor and Blake for the confirmation, appreciate it
