Is there a sensor outage?
BlakeRichardson
within 10 minutes this morning all of my main networks sensor went offline and haven't come back online. There are positioned across the entire campus so not connected to a single MR/MV or even the same edge switch.
https://status.meraki.net/# reports no issues.
Curious if anyone else is having issues, if not I will open a support ticket.
7 Replies 7
No problem here, on fw 1.5
I am on shard n85 and all of mine are online.
I just checked 5 customers and there sensors are all online as well.
All online here on 184 and 199 running MT2.0
BlakeRichardson
Hmm mine are all showing in the event log Insufficient RSSI including a door sensor that is less than 3 metres from the AP it connects to which is in the same room...
paul_richardson
I have all my MT10 go offline 2-3 hours ago
Pressing the general purpose button gives a solid green for three seconds, so in theory they are connected to a gateway
Running MT 2.0
Also located in NZ if that makes a difference
BlakeRichardson
They all came back online 2 hours later without doing anything. Suspect an issue with the Shard I am on caused them to go offline but report a faux reason.
