Setup MT30 trigger to turn MV audio off?
AlexGregoire
Before we get into the weeds - yes, using the MT trigger to power off the camera's switchport is perfectly adequate. But it's not preferred.
Is there a way to set up the MT30 trigger to only turn the camera audio to off or on through a webhook or API? It's obviously not in the other small set of preset automations. I've never set up a webhook, but skimming the first grafs give me the impression that i could set up the button to send out a web message to a web server, then . . ? And, no I'm not set up to develop an API.
1 Reply 1
Ryan_Miles
Meraki Employee All-Star
@AlexGregoire there is an API endpoints for toggling Camera audio https://developer.cisco.com/meraki/api-v1/update-device-camera-quality-and-retention/
As for getting a MT30 to do it you'd need some middleware that can take in for example a webook sent by the MT30 and then make an API call.
