Sensor firmware versions MT 2.0 changelog
New
- Update MT14 TVOC Algorithm to improve accuracy.
Bug fixes
- Update MT20 and MT30 battery state of charge curves to be more accurate. Reported battery percentages will be lower than previously reported after this upgrade by up to 20%. Overall battery life remains unchanged as this changes the battery reporting and not the actual battery life.
- Updated MT14 PM2.5 sensor fan cleaning behavior. No major behavior change expected, cleaning should still run every 3 days.
- Internally overhauled alerting wake-up logic. No behavior change expected.
- Internal bug fixes and performance improvements
