non-meraki site-to-site
route_map
Hi team
if i have 2 organizations, one using mx65 and one mx64 do i have to configure non-meraki vpn
I have followed the guides to the tee, stuck with the below error
10 Replies 10
Cmiller
I see you are using a Custom IPsec Policy. I would double and triple check them as Phase 1 isn't connecting. If all looks right try using the default profile and see it will connect
route_map
route_map
should the public ip and wan be different?
Cmiller
Generally no.... what are the ISPs for these setups? Are they using home routers? Almost always need to do some port forwarding/DMZ setup on the router.
A common cause of a phase 1 error is a mis-matching PSK.  I have also had issues in the pasy with complex PSKs and issues with specific special characters.  Perhaps try a simple PSK to being with like "password".
Are the public IPs directly on each WAN interface of each MX, or is one/both of them behind a NAT gateway?
route_map
one mx is connecting using cellulare
other one is a direct link
route_map
So i dont want to open another topic, but i am still not winning and my ISP say that havent blocked any ports.
CLient VPN doesnt work
Auto VPN doesnt work
Non Meraki VPN doesnt work
I am literally losing it
Do you have the exact same IPSec policies set on both devices as well as the PSK? Also make sure you put in all of the private subnets you want to be able to traverse the tunnel in there because your screenshots show 192.168.8.x failing but you don't have that subnet in either VPN.
Who is your ISP?
route_map
local ISP - metrofibre in South africa
ok so i changed the local subnet to 192.168.0.0/24 and added it to my local subnet to go via vpn
