- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Wireless slow on a MX64W
I have a MX64W configured as a spoke. It is connected to the hub by a Cat6 cable. The distance is approx 75 yards. The devices connected directly by patch cable to the MX have decent speed. Users are complaining about the speed of the wireless. Uplink is set at 250 bps. Suggestions on how to improve wireless bandwidth speed?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, the MX64w is not an access point, it is a security appliance with Wi-Fi capability.
The MX64w has limitations compared to an MR and is recommended for small offices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you have any traffic shaping rules configured?
How many clients do you have connected to your network simultaneously?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Uplink set at 250bps
load balancing disabled
Active-Active Auto VPN enabled
Global bandwidth limits unlimited
Default traffic shaping rules
Currently 4 clients, sometimes as many as 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you sure it's bytes per second? Isn't it 250 megabytes (MBs)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Typo its 250 Mbps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
One more question, what version are you running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MX 18.107.10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try updating to version 18.107.12.
In order to run this version you need to update to the latest stable version (18.211.5.2)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There is much less you can configure and monitor as far as the built in wireless on an MX vs an MR. Have you checked for interference? Tried updating auto channels or setting custom channels? Made sure the antennas are properly seated?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried to update auto channels but it failed. There are users connected. I'll have to try Monday when I am on site. I'll also reseat the antennas and interference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you say this, do you mean you have another MX as your main security appliance, and then you have this MX64W being used only as an access point?
Are there any other access points in the environment?
Are you saying users are 69m (75 yards) from the MX64W?
When users connect to the WiFi, is is clear and unobstructed, or do they have to go through several walls?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The MX64W is an access point. We have a MX 250 as our primary security appliance. No other access points other than the WAPs. The MX64W is approx 75 yards from the MX250 and is connected by a CAT6 cable. The users notice slow access whether they are in the same office as the MX64 or in the rest of the building.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I inherited this set up and never felt it was quite right. It's time to use the correct MR.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If it is more than 20m away from the users - I would consider adding an extra AP as well.
