So within the hub and spoke environment, if the Data vlan is set to run its own DHCP server, with its own vlan and ip range, even though there is a vpn aspect involved, their either isnt any DHCP requests being sent or received to the hub mx over that VPN unless you enable the relay, is that right?
We had some complaints about network connection at a remote site setup with its own network and its corp vlans had their own DHCP server settings, and one of our network admins thought it should be set to relay to avoid conflicts with Hub MX that points to two different MAIN campus DHCP servers. So i was wondering about any DHCP traffic that might being sent thru the vpn that we were previuosly unaware of.
