Can I mage exceptions to the static IP ranges I have in Static routes?
Tintin
Hi!
I have a bunch of static routes setup in Security & SD–WAN -> Addressing & VLANs
Now I wonder if it's possible to let specific IP addresses in the different ranges get bypassed/ignored?
For example I have this IP range set as one of the static routes 160.48.0.0/14 and it works fine, but I have one site which IP address is within that range and I'd like to exclude it from a being a part of that static route.
Is there a way to do this without having to fiddle with my lists of static routes?
1 Reply 1
Obrez
Hi, I have never tried it on an MX, but you could try using a source-based route at the bottom of addressing and vlans page.  just be very specific and careful, as you can take down your whole network.
