Third WAN
OBARRERA
Third WAN
Hi felow companions.
Can I enable a third wan port on a MX 250?
HEEELP!
6 Replies 6
DarrenOC
Hi @OBARRERA
This isn’t possible. You can only have two active WAN ports. The third would be a GSM/cellular failover option.
OBARRERA
And Meraki support can enable it fron the backend?
jbright
The new MX75 has hardware support for 3 WAN interfaces and the MX85, MX95 and MX105 have hardware support for 4 WAN interfaces. Software support for more than two WAN interfaces on these models is not expected until MX 18 firmware. Considering that MX 17 firmware only became available in Public Beta two days ago, it's going to be a while before this feature is supported.
I don't know if the MX250 and MX450 even have the hardware to support more than two WAN interfaces.
DarrenOC
Both models don’t support a third WAN and this isn’t available on the newer models currently
Inderdeep
@OBARRERA : Corrected said by @DarrenOC . Only 2 WANs !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
Techie2000
This is now possible through the MultiWAN backup feature implemented in firmware build 18.2 and higher.
Documentation: https://documentation.meraki.com/MX/MultiWAN_Backup_Uplink
