Hi all,
we've investigate an issue with MX FW 18.2xx.
With MX FW 18.1xx it works fine.
Our Branch offices with Meraki MX100, MX85,MX95 build a 3rd party VPN Tunnel to our VPN Concentrator in the Data Center MX450.
With MX FW 18.1xx all Servers behind the VPN Concentrator are reachable via ping from the branch offices. With FW 18.2xx the Servers are not reachable anymore via ping.
Has anyone else encountered this issue ?
Does the issue resolve if you roll back?
I would contact Meraki support in this instance.
Hi Darren, Yes, after rolling back to 18.1xx solve the problem.
Just to clarify, was it just ICMP that wouldn’t function or was all connectivity lost?
The connection is completely lost to the Data Center and vice versa
I suggest you open a support case to check.
Given 18.2.x is in beta, I suggest opening a case with support if you can safely put it in the broken state again.
Otherwise, remain on the 18.1.x stable firmware
Did you only try 18.205, or the new 18.207?
I had something sort of similar;
Hub 17.x in datacentre
Spoke 18.1xx in home office
Personal MX that terminates internet connection at home 18.205
The upgrade of the personal MX stopped the corporate spoke finding the hub. I downgraded to 18.1xx and it worked fine again. I haven.t had a chance to test with 18.207 but aim to over the next couple of days.
I wonder if this is an AutoVPN rebuilding issue.
Are you able to enable NAT traversal on your main hub? Even if this does not solve the problem, it makes AutoVPN more robust.
This isn't AutoVPN issue, it's 3rd Party VPN, because of 2 different Meraki Organizations involved..
BTW: It's with each branch office to the VPN Concentrator in the DC.VPN Concentrator has NAT Traversal enabled. Latest FW 18.107.7 Patch works also fine, FW 18.205/18.207 doesn't
