Hi I have a MX64 and I wanted no configure SD WAN policies but it does not appear 😞
Does anyone know what happen?
The lastest stable
I too am seeing this condition.
Latest stable firmware MX 14.53
We have ~150 MX60/64s
None are showing the SD-WAN policies
Only IP Flow Preferences.
Our standard configuration is to prefer WAN1 and only use WAN2 in a failover mode.
I have tested enabling load-balancing and active-active VPN to see if any change but none.
I do have a pair of MX84 in Asia and they DO have the proper options but are only network I can find that does.
Opened case with Meraki and they are coming up empty initially and continue to research.
OK have solution
You must have active/active tunnels enable for this to work (thinking about it makes sense otherwise you'd only have single tunnel to use)
We also had a back end change made to our dashboard long ago that disabled active/active regardless of what GUI showed.
Support was able to adjust the override in our dashboard (now that GUI works properly)
After doing that AND enabling active/active VPN and doing a full refresh on page we see VPN flow preferences!
What in particular are you trying to do?
Flow preferences are available if you click "Add a preference".
Your traffic shaping rules should be further down the page.
If you only have one MX64 in the organization you cannot configure an SD-WAN, you need at least two, one each in separate networks.
Mmm I don´t think so, bc I have customers with just one MX and one branch and they have this option.
Regards
Yes but in this option I just configure L3 rules to prefer the outbound traffic flow.
Regards
Hi John,
do you find the solution for this issue? I get the same issue. if you have the solution, please share me.
Thanks and regard
They already gave you the solution in the discussion you created.
