Meraki MX - Viewing traffic logs
LeAnts
Hi All,
new setup on meraki.. we have the following outbound rules.
LAN -> Internet allows ports http(s), dns, ntp, ping - very basic
Then i have another rule to with any any allow..
is there a way i can audit what traffic is being passed over the any any allow rule? i see hits but unable to determine what ports/dest IPs are still going out.
no syslog configured at this stage as in POC testing atm.
thanks
6 Replies 6
You have to enable the syslog configuration.
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Syslog_Server_Overv...
Explaining better, you need to send the logs to a syslog server, the dashbord does not have detailed information.
CptnCrnch
LeAnts
thanks for the info.. guess i will configure syslog then...
LeAnts
ah.. i like the logging tool option.. but we are running version 18.107.2
if i were to upgrade, what is the most stable release in 18.2 to use?
many thanks
Latest rc is MX 18.211.0.1
