SD-WAN Policies does not appear in SD-WAN & traffic shaping page
Phu_LeoNguyen
I need to configure in option SD-WAN Policies. But in my SD-WAN & traffic shaping page. i don't see SD-WAN Policies. Please help me know how to unhide the SD-WAN Policies. My device is MX250 and current version: MX 18.107.2
Best reagard.
10 Replies 10
Brash
A few things to check:
 - Is the network you're trying to make changes on bound to a template? If so, you will need to make the changes on the template instead (which will impact every network bound to it).
 - Is your user an Administrator for the Org or for this Network?
 - Is the MX deployed in routed mode or as a VPN concentrator?
Phu_LeoNguyen
Thanks for your support.
After checked, i can tell you:
_ My network i want to make changes. it does not have any template
_ My account is master. i can configure all networks
_But the last one. How i need to check to see my MX deployed in routed mode or as a VPN concentrator?
Its on top of the page
Security & Sdwan > adressing & vlans
Phu_LeoNguyen
oh thank you.
it's routed mode @Brash
You have the network configured as a spoke or hub - haven't you?
SD-WAN has to be enabled to use SD-WAN traffic shaping policies ...
Phu_LeoNguyen
No, my network currently just like this
That is your issue.  You have to enable SD-WAN to use SD-WAN traffic shaping.
Phu_LeoNguyen
Hi, so i have to choose hub or spoke.
But when i change this option. Does any affections cause my network.
Take a read over these SD-WAN instructions.  Once you have taken that in, you should be well-placed on what kind of configuration to make.
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
Another thing you could try is looking at other SD-WAN nodes in your organisation and see how they are set up and create a similar configuration.
