Reset configuration on MX Appliance
Tekrondo
I want to reset the configuration on my MX100, there's no obvious way of clearing the configuration.
Would removing and deleting it from my inventory clear the cached config and settings?
I still would be using it in the same dashboard, just on a different network.
AjitKumar
Hi
I hope you have gone through the following Url.
This document give us the detailed procedure of resetting the devices to Factory Defaults.
https://documentation.meraki.com/zGeneral_Administration/Support/Resetting_Cisco_Meraki_Devices_to_F...)
Also deleting from Inventory and moving to another network will download the configuration of "New Network" from Meraki cloud overwriting the existing on to the MX100.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
AjitKumar
Hi
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
As @AjitKumar says, all you really need to do is just move the MX to the new network, and it will get a new config.
Adam
I believe the only thing that won't get cleared by going through the above suggestions is the local static IP information which you can adjust by going to the local mgmt page.
