OSPF Configuration for 2 sites
ampsta
I have site A- Main site and Site B secondary site.
Site A- MX100 and MS350 48fp
Site B- MX100 and MS350 48fp
How do I setup OSPF to advertise routes between sites? Should site A be area 0 and site B area 1?
jdsilva
Check out these two links. They should help with this.
For OSPF, in what you describe you would just make both part of Area 0. Area boundaries are on layer 3 devices, not between layer 3 devices. You can get a pretty big number of routers in an area without having to worry about areas.
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_Overview
https://documentation.meraki.com/MS/Layer_3_Switching/MS_OSPF_Overview
2 REPLIES 2
jdsilva
You won't be able to use OSPF between the sites - you should not need it.
In each case, the default route for each switch should point to its local MX.  The MX will need to know the routes in use at each site already, and you simply include those in AutoVPN.
