Hi all,
I am just wondering if other of you experience the same issue.
I have a MX 67 in place and I would like to use the packet capture function.
Now every ones in a while it works quite well. Means I start it, I filter on a host and the output can be seen in the window below.
But most of the time I start a capture and nothing happens except the the turning circle. Also if i start it and stop it again...most of the time no output but sometimes output will display.
I am just wondering if this capture feature is not reliable or what could be the issue.
I set even a filter to a host address in order that i will not have to much output.
Intrested in your experience.
rgds
roger
