Odd SD-WAN Traffic Behavior - *Some* Traffic from Concentrators Arriving on WAN2, not WAN1
Crocker
Our topology is classic hub and spoke. We have 2 hubs (at separate datacenters), configured in one-armed concentrator mode. On the spoke side, we use full-tunnel active/active AutoVPN. Our spokes generally have a wired ISP connected to WAN 1, and an MG21 on WAN 2.
Our spoke-side SD-WAN policy is simple. We instruct the local VOIP subnet to "use the uplink that's best for VOIP", which I understand is based on MOS. The rest of the traffic has no associated policy, thus should only traverse WAN 2 if WAN 1 goes down hard.
What I'm seeing is that if I run a packet capture on the Site-To-Site VPN over WAN 2, there are a handful of packets sourced from our VOIP controllers traversing WAN 2. *Most* of a given flow is bidirectional across WAN1 (verified by running side-by-side packet captures), but occasionally a few packets come in across WAN2. I've double-checked the VPN statistics, and WAN1 is consistently at a MOS of 4.1, while WAN2 wavers a fair bit (due to bad cellular reception) from 2.5-3.8.
As far as I can tell, I should never see any traffic over the Site-To-Site VPN cross WAN 2...However, I'm absolutely seeing this occur.
What got me looking at this in the first place was a complaint about VOIP quality from a specific spoke. I found that disabling WAN 2 cleared up the issue (which again, is a bit cruddy due to bad cellular service).
I know the 'fix' for the VOIP complaints is likely to either leave WAN 2 disabled (or adjust the VOIP policy to only shift traffic if WAN 1 is hard down); However...I'm stumped as to why *some* traffic from my hub to my spoke is crossing WAN 2.
Any insights? I do have a ticket open with Support regarding this behavior, but thought I'd ask the community as well.
5 Replies 5
In case the phone service has ever failed over to wan2. And the phone keeps a active session it stays forever( till the sessions  times out) on wan2.
Crocker
I wondered about this; However, I knocked WAN2 down for 10-15 minutes (assuming that was long enough to sever any flows). When I stood it back up, I immediately started seeing this behavior.
DarrenOC
Hi @Crocker - what version of firmware are you running?  Sounds like a bug to me.  Have you trawled through your other SD-WAN & Traffic shaping settings to ensure you have nothing erroneous configured?
I would assume you have your Primary uplink set as WAN1.  For giggles have you tried flicking WAN failover and fallback from Graceful to Immediate?
As you've correctly stated absolutely no traffic should be touching WAN2 until the Primary link fails.
Crocker
We're running 16.16.8 across the board, due to some unrelated issues regarding MX17/18's IPv6 support and some carrier modems with really low IPv6 DHCPv6.
Unfortunately, that also means we don't have the option to select between graceful/immediate for WAN failover/fallback. I'm unsure what the 'default' is, in MX16.
I did double and triple check our SD-WAN policy, but nothing in there looks out of place. Additionally, I'm using VOIP traffic as the example in my original post but I see other traffic (SNMP between our Solarwinds poller and the MX/MS's on-site) behaving the exact same way. That traffic absolutely is not affected by an SD-WAN policy, and should only ever traverse WAN 2 if WAN 1 goes down hard.
When speaking with support yesterday, there was a little back-and-forth over whether this behavior was actually expected. I was told that the only real way to ensure traffic inbound to the spoke doesn't traverse WAN 2 would be to disable active/active AutoVPN. Wasn't particularly pleased with that answer, as it sort of dodges the crux of the issue.
Crocker
Any Meraki folks haunting the forum who have any thoughts on this? I guess basically the question boils down to:
How does a VPN concentrator determine which tunnel to use to send traffic to a destination at a spoke site with Active/Active AutoVPN enabled? Should I just expect to see occasional packets inbound over WAN2 for no apparent reason? The answer I got from support wasn't particularly clear, but I'd paraphrase it as "We don't know but we also don't think it's a problem"
