Greetings -
Is it possible to integrate the Meraki Z3 teleworker gateway with a non-Meraki MX at the head-end? Perhaps a Cisco NGFW2130?
I am assuming "no" but I figured I'd get the official answer here.
Cheers,
Joe
Solved! Go to solution.
Yes. 3rd Part VPN tunnels are supported and I have used them many times. Its not feature rich, but it works.
https://documentation.meraki.com/MX/Site-to-site_VPN/Configuring_Site-to-site_VPN_between_MX_Applian...
@cwf
Yes, that is what I was referring to. I saw the option for the Meraki MX AutoVPN feature but was wondering if it would support VPN tunnels with a non-Meraki MX appliance.
Cheers
At this point I just need split-tunneling on the Meraki Z3 side. It's for a couple of 'work-from-home' colleagues.
Thank you for the information/link.
https://community.meraki.com/t5/Security-SD-WAN/Backhaul-internet-breakout-to-non-meraki-VPN-peer/m-...
