Greetings -
Is it possible to integrate the Meraki Z3 teleworker gateway with a non-Meraki MX at the head-end? Perhaps a Cisco NGFW2130?
I am assuming "no" but I figured I'd get the official answer here.
Cheers,
Joe
Solved! Go to solution.
Yes. 3rd Part VPN tunnels are supported and I have used them many times. Its not feature rich, but it works.
Yes, that is what I was referring to. I saw the option for the Meraki MX AutoVPN feature but was wondering if it would support VPN tunnels with a non-Meraki MX appliance.
Cheers
Joe
At this point I just need split-tunneling on the Meraki Z3 side. It's for a couple of 'work-from-home' colleagues.
Thank you for the information/link.
Cheers,
Joe
